inserting component
When inserting a component into an assembly my component goes to full screen and you can no longer select references from the main assembly. I have tried toggling the tool options in the bottom right. The only thing I can do is close the component window. Is there some setting for this?
It is after you select the component. You can toggle the show component in separate window.
It appears what is happening is if the component is open already and you are in the assembly and you go to insert this item it is reverting to the open component window and making this active instead of opening it in a separate component window.
We are running 3.0. i can't duplicate my issue on another users computer at our office either.
