instance not in workspace, when generic not in same folder
  • September 6, 2012
  • 0 replies
  • 617 views
Hi all,
I have noticed something strange and would like to know if this is a common situation or if something is wrong.
When I add an instance to use in an assembly then normaly both the instance and the generic are added to my workspace. BUT i noticed that when the generic is not located in the same folder in windchill, then only the Generic is added to the workspace and no sign of the instance. while the instance is correctly added in the assembly.
I'm able to save and check in my assembly without any problems..
when then checking in my assembly and Remove all dependent parts with it from my workspace, that specific generic won't automaticaly remove either..
It's not that i have crucial problems because this is happening, but i also know that this is not supposed to be like that.
any thoughts?
Grtz
Arno
