7-Bedrock
July 15, 2011
Interchange + family tables
  • July 15, 2011
  • 5 replies
  • 3111 views
I have a problem with replacing sub assemblies through a interchange assembly in an other fam. table.
For example:
  • 0211545_PLAC005.ASM is an instance of BUSHING_PLAC005.ASM
    This has a arcing horn 0215353_PLAC002.ASM and is an instance of ARCING_HORN_BOTTOM_PLAC002.ASM.
  • 0211575_PLAC005.ASM is an instance of BUSHING_PLAC005.ASM
    This has a arcing horn 0215353_PLAC003.ASM and is an instance of ARCING_HORN_BOTTOM_PLAC003.ASM.
I have placed generic models ARCING_HORN_BOTTOM_PLAC002.ASM and ARCING_HORN_BOTTOM_PLAC003.ASM in a interchange assembly.
The problem is now if I replace 0211545_PLAC005.ASM to 0211575_PLAC005.ASM it can not find assembly 0215353_PLAC003.ASM.
I think it should find it through the interchange assembly but it does not work properly. If I retrieve the assembly 0215353_PLAC003.ASM in session then it works but it should it automatically.
How can I let it work properly?
Best regards, Koen.
Is everything in the same directory? You may just be having a search path problem.
7-Bedrock
July 15, 2011
Hi, the models are in a library. Not in the working directory. But I work with a catalog file and all the models in the library are in the same folder.
But I will investigate this further on monday.
Best regards, Koen.
