Is export graph to Excel limited to 100 points in Creo Simulate?
Hello all
Although the issue may be around since old versions, the help file for “Exporting Results” does not explicitly indicate any point limitation when exporting a graph to Excel.
Basically I ran a thermal transient analysis that converged to stead state in a bit more than 170 steps. After I plotted the graph “Temperature x Time” and it was not complete. I had to changed the X scale to howed all points.
However when exporting the graph as excel only the 1st 100 points were exported – independently how the graph was formatted.
Is 100 points export in excel and the fact that it ignores the format of the graph a real software limitation or a bug?
In any case, how I can take all the data generated during a transient analysis (or even other analysis that outputs more than 100 points).
Thank you in advance for any feedback.
Best regards
R. Rabe
Ps: Another funny thing with Creo and excel is that each time that I copy the values from a Creo generated excel file into a new excel file it freezes the new spreadsheet – the unique option is thus to close it!
