Is it possible to convert a B-rep model to CSG model in Creo?
  • April 30, 2016
  • 2 replies
  • 2202 views
I have imported some surfaces and I want to create a closed surface model. In the second step, this surface model has to be converted to a solid model. Does creo support this function? Or does Creo support hybrid model (one part is consisted of both face model and solid model)? Thank you
Creo is not a basic CSG modeler. It is a B-REP parameterized procedural modeler. It has Merge to join surfaces into a water-tight surface which can be solidified. Depending on what support you want, it does support mixed mode - wireframe, surface, and solid geometry operations simultaneously in a single model. It does not support solid geometry cuts on wireframe and surface geometry, but it supports calculating intersecting geometry between the B-REP surfaces of the solid model and surface and wireframe geometry that can be used to perform some trimming operations.
Though this lists Creo as CSG, Constructive solid geometry - Wikipedia, the free encyclopedia, Creo doesn't support the feature operations typical of a CSG modeler, such as Intersect; which is the ability to create a solid that is the volume common between two other volumes. It only does Union and Subtract, though they are now lumped into Protrusion. CSG also tends not to have interdependent geometry. Traditional CSG features are independently placed and have independent.
What Creo does have are features such as Replace - where a face of a model can be replaced by a surface, which is definitely not a CSG operation.
David Schenken wrote:
... Creo doesn't support the feature operations typical of a CSG modeler, such as Intersect; which is the ability to create a solid that is the volume common between two other volumes.
However, when working with quilts (surface patches, either closed or open) rather than solids, much of this type of functionality (as I understand it) can be achieved through the Merge command.
By choosing to keep either side of each of two intersecting quilts (four options in total), the result can be the union, the intersection, or either difference (subtract A from B, or B from A).
In a variation from 'regular' CSG, only the portion of each surface which is kept needs to be watertight - you can intersect two open quilts to form a closed quilt.
