is there a standard .dmt file with 50 basic colours
  • February 14, 2014
  • 2 replies
  • 2672 views
Does anyone have a .dmt appearance file I can use? I would like to be able to down load a .dmt file that has about 50 pre loaded colours. So far I only have one colour grey and I have to make them all as I go which is slow. I use pro/engineer wildfire_4. thanks for yourtime. from David
Best answer by HamsterNL
http://community.planetptc.com/thread/4567
or
http://grabcad.com/library/ral_colors-dmt/files (found with a simple Google search)
HamsterNL
HamsterNL18-OpalAnswer
18-Opal
February 15, 2014
Basic Creo Parametric Color Map
You can cut and paste sections of the attached file or maybe it will work as-is in WF4. You might need to set the number of colors allowed in the config.pro file.
Welcome to the forum, David.
