It would be nice to insert jog on a radius dimension, so dimension is link to model.
  • April 29, 2016
  • 2 replies
  • 5915 views
Dale_Rosema
Not sure if this is what you are asking for, if not, maybe provide a picture of what you are asking:
Re: Can't break dimensions outside view boundary... how to break manually?
Thanks, Dale
SkyKing10-MarbleAuthor
I had to create a note to get the R.053 where I want it.
As a workaround, you can
  1. Use the 'switch symbols' toolbutton (or edit the dimension properties) to identify the dimension name, which should be something like 'd27'
  2. Create a note and for the text, enter 'R&d27'
The note now contains the actual dimension parameter, and will update parametrically in both directions (model to drawing and drawing to model).
StephenW
