Layout (Notebook) Table of Parameters: Blank but Populating?
  • January 26, 2012
  • 5 replies
  • 3351 views
Hello Users
In a Layout, my Table of Parameters is populating but is blank
Interestingly, this procedure correctly renders the Table of Parameters in a Drawing file
  1. In Creo 1.0
  2. .LAY file created with Parameters
  3. Table Created with Repeat Regions
  4. Cells entered - lay.param.name , lay.param.value
  5. Table Updated
  6. Rows populate for Parameters entered
  7. Cells are blank (?)
File is attached.
Thank you kindly in advance
Does anyone else have this problem?
Updated to M020 and did not fix the issue.
Using &[PARAMETER_NAME] works, but Repeat Regions are not working correctly.
Hi Peter...
I'm sorry no one has responded yet. Hopefully some Layout guru will chime in. All I can tell you from my experience is that Layouts are very rarely used. This is likely why there have been few responses.
I'll fight to hold back my editorial comments on Pro/NOTEBOOK for another time.
Good luck!!
-Brian
