Jul 7, 2020 1:23 AM UTC
Leader Note With Ballon Note
Community,
Is there a way to make a leader note that contains a non-leader balloon note that has a number?  For example, you have a leader note that contains part number and beside the part number will be a circled item number.  I want to combine the two so if I need to move the view, the two will float with the view.
kdirth
kdirthAnswer
Jul 7, 2020 12:07 PM UTC
Create an offset balloon note.  This attaches the balloon note to an object.  After creation, you can select the balloon note and use Relate to Object or or Relate to View.
These options make the item move with the object or view it is attached to.
kdirth
kdirth21-Topaz IAnswer
ThoRig14-AlexandriteAuthor
Jul 7, 2020 12:25 PM UTC
Here is an example of what I am trying to do.  You gave the correct solution before I could post this, but I just wanted to give the audience something visual to go by.  Thanks.
kdirth
Jul 7, 2020 5:41 PM UTC
I would normally create a balloon note with leader, then attach an offset note for what you are showing.
You may also what to check out this topic:  Put-a-circle-around-text-in-a-note
