let weak dimension modify automatically
- July 28, 2018
- 8 replies
- 5079 views
i have faced this problem often.. (and an annoying thing in Creo)..
lets say i have a simple sketch as shown in the attachment,
i have given the overall dimension is 120mm , now when i tried to change the overall dimension to 130mm , it won't change...
i will have to delete the dimension (120) drag the curve to nearest point to 130 and then if i give the 130 dimension .. it will work ..
is there way ti disable to weak dimensions from governing the curve and let it change automatically when i give a dimension .... ?
thanks in advance....
