m130 vs m140 - speed
  • February 24, 2015
  • 1284 views
I ran Olaf's benchmark on both versions same machine. This is what I'm getting. I've hi-lited 3 items that are much slower.
Anyone else getting the same type of results?
Version
M130
M140
Test
Result1
Result2
Diff
Retrieve generic assembly (CP)
40
40
0.00%
Retrieve assembly 1 (CP)
45
47
4.44%
Retrieve assembly 2 (CP)
51
52
1.96%
Retrieve assembly 3 (CP)
59
59
0.00%
Retrieve assembly 4 (CP)
65
65
0.00%
Retrieve assembly 5 (CP)
73
72
-1.37%
Retrieve assembly 6 (CP)
79
80
1.27%
Retrieve assembly 7 (CP)
84
84
0.00%
Retrieve assembly 8 (CP)
92
93
1.09%
Retrieve largest assembly (GR)
6
5
-16.67%
100 wireframe view redraws (GR)
43
47
9.30%
40 wireframe view redraws with DATUMS on (GR)
35
39
11.43%
1 hidden view redraws (GR)
50
50
0.00%
80 hidden view redraws with Fast HLR (GR)
34
101
197.06%
80 shaded mouse spins (GR)
28
31
10.71%
20 shaded mouse spins with reflection (GR)
12
14
16.67%
100 shaded view redraws (GR)
40
47
17.50%
60 shaded view redraws with edges (GR)
25
31
24.00%
5 shaded pan and zoom (GR)
52
54
3.85%
9 wireframe mouse zooms (GR)
31
64
106.45%
initiate advanced shaded mode (CP)
36
26
-27.78%
3 advanced shaded mouse zooms (GR)
50
58
16.00%
20 very advanced shaded spins (GR)
65
45
-30.77%
4 save jpeg (CP)
21
20
-4.76%
end advanced shaded mode (CP)
21
17
-19.05%
8 screen translates (GR)
29
36
24.14%
10 automatic regenerates (CP)
50
56
12.00%
30 Perspective views (GR)
49
59
20.41%
2 mass prop calculations (CP)
66
67
1.52%
3 global interference checks (CP)
47
43
-8.51%
1 IGES exports (CP+DI)
346
480
38.73%
4 STEP exports (CP+DI)
47
46
-2.13%
1 drawing creations (CP)
54
64
18.52%
1 regen views HIDDEN LINE (CP)
80
81
1.25%
1 regen views NO HIDDEN (CP)
75
74
-1.33%
1 PDF file creations (CP+DI)
115
106
-7.83%
1 DXF File creations (CP+DI)
87
81
-6.90%
Erase all from memory (MEM)
228
80
-64.91%
Total
2410
2514
4.32%
Graphics
549
681
24.04%
CPU
1633
1753
7.35%
Disk
595
713
19.83%
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
Hi David,
I've done some tests (best result out of three runs) and cannot reproduce your results:
Nor when compared to M120:
Did you double check clearing all configuration files for your M140 setup?
Kind regards,
Olaf Corten
Olaf Corten | CAD/PLM Manager
Besi Netherlands B.V. | Ratio 6| 6921RW Duiven| The Netherlands
T: +31 26 3196215 | M: +31 644548554
- | www.besi.com
To: "-" <->
Date: 24-02-2015 22:20
Subject: [proecad] - m130 vs m140 - speed
I ran Olaf’s benchmark on both versions same machine. This is what I’m getting. I’ve hi-lited 3 items that are much slower.
VersionM130 M140 TestResult1Result2DiffRetrieve generic assembly (CP)40400.00%Retrieve assembly 1 (CP)45474.44%Retrieve assembly 2 (CP)51521.96%Retrieve assembly 3 (CP)59590.00%Retrieve assembly 4 (CP)65650.00%Retrieve assembly 5 (CP)7372-1.37%Retrieve assembly 6 (CP)79801.27%Retrieve assembly 7 (CP)84840.00%Retrieve assembly 8 (CP)92931.09%Retrieve largest assembly (GR)65-16.67%100 wireframe view redraws (GR)43479.30%40 wireframe view redraws with DATUMS on (GR)353911.43%1 hidden view redraws (GR)50500.00%80 hidden view redraws with Fast HLR (GR)34101197.06%80 shaded mouse spins (GR)283110.71%20 shaded mouse spins with reflection (GR)121416.67%100 shaded view redraws (GR)404717.50%60 shaded view redraws with edges (GR)253124.00%5 shaded pan and zoom (GR)52543.85%9 wireframe mouse zooms (GR)3164106.45%initiate advanced shaded mode (CP)3626-27.78%3 advanced shaded mouse zooms (GR)505816.00%20 very advanced shaded spins (GR)6545-30.77%4 save jpeg (CP)2120-4.76%end advanced shaded mode (CP)2117-19.05%8 screen translates (GR)293624.14%10 automatic regenerates (CP)505612.00%30 Perspective views (GR)495920.41%2 mass prop calculations (CP)66671.52%3 global interference checks (CP)4743-8.51%1 IGES exports (CP+DI)34648038.73%4 STEP exports (CP+DI)4746-2.13%1 drawing creations (CP)546418.52%1 regen views HIDDEN LINE (CP)80811.25%1 regen views NO HIDDEN (CP)7574-1.33%1 PDF file creations (CP+DI)115106-7.83%1 DXF File creations (CP+DI)8781-6.90%Erase all from memory (MEM)22880-64.91% Total241025144.32%Graphics54968124.04%CPU163317537.35%Disk59571319.83%
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Livermore, CA 94550
Site Links: View post online View mailing list online Start new thread via email Unsubscribe from this mailing list Manage your subscription
Use of this email content is governed by the terms of service at:
