Machine bend of individual pipe
I have made a pipe with the Pipe module and have split it into manufacturable pipe sections. I now want to make drawings of each section and show the machine bend table in a table.
How do I do that?
If I open up the part and make a drawing of it, I can't access the saved machine bend table, as it was made in the assembly. Piping only works in the assembly mode, so I can't make a machine bend table within the part/section. Alternativel I can make a view state in the assembly with only the pipe section that I want, which I can put in a drawing. If I then make several different machine bend table analyses and save them in different names (for the different pipe sections), I get all of them in the same repeat table in a drawing. How can I filter or remove the ones (machine bend table analyses) I don't want in the current drawing?
