2-Explorer
Jan 11, 2019 9:32 PM UTC
Make Surface Copy Independent - Creo 2.0
See attachment. I have some surface copies that I need to be able to make independent to break the dependencies so that I can check the files into windchill.
I don't care if the surfaces get frozen and aren't linked to anything anymore.
JM_LPEAnswer
2-Explorer
Jan 22, 2019 4:45 PM UTC
So I found that if you make an independent geometry feature, then collapse the surface copy to the independent geometry feature, it gets rid of the dependency.
Quite a few more steps than opening the reference viewer and and RMB->Break Dependency, but it gets the job done.
6-Contributor
Jan 14, 2019 11:32 AM UTC
In Reference viewer switch to show Dependencies instead of References and now you should can do Break Dependency with right click on dependencies arrows.
JM_LPE2-ExplorerAuthor
2-Explorer
Jan 14, 2019 3:57 PM UTC
See attached. I don't see a Break Dependency option. Why would this not show up?
6-Contributor
Jan 14, 2019 4:34 PM UTC
I think reason because you don't see the option to break dependency is that you used copy/paste method for creation of this surfaces. I created surfaces with Copy Geometry command and I was able to break dependency like I described.
2-Explorer
Nov 11, 2019 2:16 PM UTC
You can copy features from the Assembly window into another part within the assembly window, this will kill the dependency. or copy and save into a stp or iges...
It is not so convenient as the options available on creo 4.0 and upwards.
