Manufacturing cutting tool adapter directory
Currently, you can't load user-defined path fo adapter.
Idea : Add a config option to set the default directory for manufacturing cutting tool adapter.
In the same way as for cutting tools, work center, parameters ...
for example :
"pro_mf_adapter_dir : set the default directory for the manufacturing adapter files"
