Map Key not Loading And Diffrent Drawing Properties
I have Two Questions
1.I have set lot of map keys And I have saved in Config.pro file and this files location directory is same as start up directory
but when i change working directory it automatically chanes config.pro options so every time i have to load the config.pro file
is thier any way through which i need not to load config .pro file evry time i sart up the pro-e or change the working directory
2.is it possible to have two diffrent .dtl file setting in drawing becos i made an assembly drawing which is in A3 sheet but for the sub parts i am using A4 sheet now the problem is i need two diffrent dimension style (text height and Arrow ) in same drawing can somebody have a solution for this ?
