Mass Properties Report Decimal Point
I do not understand the placement of decimal points in the Mass Properties Reports.
Is there a setting someplace that needs corrected?
Example:
I have created a model of a 12" cube with properties of aluminum for this test purpose.
The report I see is erroneous:
VOLUME = 1.7280000e+03 INCH^3
SURFACE AREA = 8.6400000e+02 INCH^2
DENSITY = 9.7543688e-02 POUND / INCH^3
MASS = 1.6855549e+02 POUND
The cube should be:
VOLUME = 1728.0000 INCH^3
SURFACE AREA = 864.0000 INCH^2
DENSITY = 9.7543688e-02 POUND / INCH^3 - I can buy this because there should be no change.
MASS = 168.555 POUND
