material appeareance - no color when assigning material
Dear All,
 creo material appearance
I observe strange behaviour of creo in assigning colour that match material's appearance setup - part turn white after assigning material.
/my version 5.0.1.0, but it also was in previously installed 4.0/
Behaviour:
  • Assign material to a part
    • There is no colour - part turns white from default colour
  • I modify the appearance /default appearance/
    • Save this material - by save to library
  • Assign modified material to a part colour was taken from the material appearance correctly
  • When I turn off the creo and reopen it
  • Assign same material modified before
    • Part turns white In material properties of this material
    • Nearly all colours in material appearances window, turned white
In my config.pro appearance catalog, color.dmt file - is set to default Creo 5.0.1.0\Common Files\graphic-library\appearances
How to fix it? Is there any options that controls this behaviour?
Thanks in advance for your help.
Regards!
I guess that color definition must be present in global.dmt file.
Same thing is happening to me. I can see that the global.dmt is not getting updated when I define the material appearance. Set the global_appearance_file option and made sure I have write access the the file too
Is this a bug?
Creo 4.0 M070
Patriot_1776
I'm on Creo 3
I have a family table of parts where I swap out the material (offhand I think it is PTC_MATERIAL_NAME) for each instance.  Creo has ALWAYS had issues with this.  In my case what I found was that whatever the last appearance was in the instance either added to the assembly, or regenerated from the table, it made all the other instances that color but kept the actual correct material properties assigned to each instance.  Whew!  I don't believe that the color has to be in the .dmt file.  It shouldn't, because the model has the definition in the material.  I've changed the material of a non family table part and it updates just fine.
I'd say there's still a bug in the system from way back.
