18-Opal
February 11, 2014
Material Assigning in Instances
  • February 11, 2014
  • 35 replies
  • 10546 views
I've added a column for the material in my family table using PTC_MATERIAL_NAME. However, any instance that doesn't use the assigned Generic material has a regeneration issue. Whenever I press regenerate it says "Material XXXX was assigned to the part" in the message log. And this occurs for any higher level assemblies that use this part. I'm expecting no regeneration to occur if nothing has changed. The higher level assy should say "Automatic regeneration of the parts has been completed.". However, with the instance inside of the assembly, it doesn't say that. It keep on regenerating the assembly and saying "Material XXXXX was assigned to the part. Automatic regeneration of the parts has been completed." I would like to avoid this at all costs because I don't like my assemblies to regenerate if nothing has changed. It causes nightmares when the assembly is promoted and released in Windchill but still used in higher level assemblies. Can anyone help me with this? The easy answer would be to not have the PTC_Material_Name in the family table. I would like to avoid that if possible.
Joseph,
I tested your problem in Creo Parametric 2.0 M090 (without Windchill). The problem disappeared when I saved Instance Accelerators for family table instances. Unfortunatelly I don't know how Windchill manages Instance Accelerators...
Martin Hanak
jwagh18-OpalAuthor
18-Opal
February 11, 2014
Martin,
I did save the instance accelerators for the instances and it still gave me issues when the instances were placed in an assembly. My specific example is a standoff family table where a swage standoff is going in a board assembly.
Joseph,
it is possible that the problem is related to your data. If you want I can send you my test models (let me know what ProE/Creo release do you use).
Martin Hanak
What problem does it cause?
If the items are released, they can't be checked in, so Windchill won't see any change.
jwagh18-OpalAuthor
18-Opal
February 11, 2014
It still regenerates unecessarily, causing any higher level assemblies to regenerate. I'd rather it say "Automatic regeneration of the parts has been completed." if possible. These are going to be library parts for about 30 mechanical engineers. I don't need people complaining that the instance is causing their assemblies to regenerate when nothing changed.
It's probably due to the mass properties being recalculated based on the material properties. I've seen this calculation forced by a relation that sets a parameter equal to the mass properties so that the value of the parameter can be pushed to Intralink or PDMLink.
It's possible that eliminating such a relation might quiet the behavior.
An alternative is to open an SPR with PTC.
jwagh18-OpalAuthor
18-Opal
February 11, 2014
Attached is a test assembly (zipped).
Just open it up and press Regenerate. Every time you regenerate it keeps on assigning material to the instance.
Does it need to have a material assigned to it? Maybe if you just assign a mass density...
jwagh18-OpalAuthor
18-Opal
February 12, 2014
yeah... if there isn't a solution to this, that is what I'll end up doing.
BTW, what part is it that it's made in so many different materials that it would need a family table for it? Can't you just make seperate parts?
