MBD 3D Annotation / changing text formats by copy paste (format painter)
Hello
We use Creo Parametrics 8.0, creating MBD in 3D and I face the following situation.
in an already created Combination State I have adjusted the text size of the so far created annotations and now I add new geometrical tolerance to one dimension.
The new created GeoTol gets the default text size, which is much too big.
Does Creo Parametrics provide an option to transfer(copy past) the text format similar as in Windows Word the "Format Painter".
I know this option from different other CAD tools, but cannot find it in Creo Parametrics.
Does such an option exist? And where can I find it?
Thank's for your support.
pausobAnswer
Not the same work-flow direction as the format painter, but I think that:
1) you can select annotation(s?) that you want to change
2) then switch to the "Format" tab, then use the "copy text style" function to make them look like another, already existing text...
if you want to use different text height for all annotations then you can set default text height.
  • File > Prepare > Model Properties > Detail Options > change
  • set text_height option
Please test whether the above solution works well for you.
Pius14-AlexandriteAuthor
Hi Martin Hanak
Unfortunately, this is no option.
As we use different zoom position of the 3D geometry to show details and over all views in combination states, we like to have the text adjusted to this zoom positions.
Thank’s for reply!
Regards
Pius
pausob19-TanzaniteAnswer
perfect!
I did not know it so far 🙂
As improved solution I add the "copy text style" function to the mini toolbar annotation menu.
Thank's a lot!
As an very good option I could imagine too, if the Combination State get's this definition and all annotations take-over this format.
