MBD: Dimensions
  • June 9, 2016
  • 3 replies
  • 3248 views
Attached to this blog post are two pieces of content that should help you as you try out the new enhancements to Dimensions in Creo 4.0.
Any questions or feedback you have related to Dimensions should be provided as comments to the blog post.
That will be the easiest way for me to keep track of the comments and also be able to provide timely responses to your questions. If you follow this post, you can be notified of those comments as well and be able to learn from what others are asking. I may also periodically update this post to add some new details or information related to Dimensions.
Also, don't forget to follow the main blog post for MBD - which will have links to other MBD-related content. Creo 4.0 MBD Home: Start Here!
I tried to put a linear dimension (with tolerance), but the tolerance button (blue circle in the picture) remained off. How to add linear dimension with tolerance value in the Sneak peek version? Thanks
Solved. I have changed the tol_d setting in configuration editor. Thanks
Yes, you found the solution!
I'm glad it's working for you now and I'm sorry I missed responding to this question sooner...
