Measure force with skeleton
I am working on a Crane assembly with mechnisam.
If I assemble all the parts/assembly using connection without skeleton, and I run a dynamic motion analysis, I can measure the force of the slider(hydraulic cylinder) force needed during the motion of the crane. However, if I use motion skeleton and assemble all the parts/assembly to the skeleton, I can not get the correct force.
Is that means skeleton can not be used in measuring the force?
