Mechanism connection for helical surface?
  • May 29, 2015
  • 2182 views
Is there any way to make a Mechanism connection for a helical surface? I have two cams that twist when contacting each other due to helical surface geometry on each, but I cant make a cam connection between them. I also cant use 3d point connection because there isn't a round surface. Is there anyway to connect the two surfaces in the mechanism application?
I have gone through great pains to emulate the motion I wished Creo would do for me.
You might be able to generate trace curves or intersects that you constrain your cam to.
mkeller1-VisitorAuthor
Okay,thats what I had in mind but I am not sure how to go about doing that. Do you have any tips for making a circular curve that follows a helical surface?
2-Explorer
June 9, 2015
Do you mean a helical curve? (can be done when intersecting helical surface with a cylinder through same axis)
Or a circle projected onto helical surface? (can be done by projecting a sketched curve onto the surfaces)
Or something else?
