Mechanism Dynamic Motion Failing, Kinematic works fine
Anyone had an issue where you have a kinematic mechanism model run perfectly fine but the dynamic run fails almost instantly.
I have a farely large chain model that uses 156 cam connections and a sprocket to move the chain around a fix body. It works great kinematically but fails within a .02seconds into the dynamic run.
Does anyone have any previous experience with models that use a lot cam connections? I'm assuming that's what is biting me with this model. Or any experience with large mechanism models run ina dynamic analysis that failed for any particular reason.
I've tried increasing and decreasing the accuracy of the mechanism assembly settings, but still it fails aroundthe same time.
