merge/inheritance
  • January 12, 2015
  • 3 replies
  • 2489 views
Hi
iam using creo 1.0 . I create a casting and machining models using family table. I will try merge/inheritance feature. My requirement is casting model and want to create a machine part using the merge command in part modeling. but in the part modelling merge/inheritance feature is not working .any one please suggest.
Welcome to the forum, Pavan.
I am not sure I understand the need for the Merge... since you can do machining in a next-level assembly.
If I understand correctly, you must have an assembly to force a merge into a lower level part.
I will admit not being fully versed in this process, so I am sure there are other thoughts coming on this.
I could be wrong, but this sounds like an accuracy issue. Try setting the accuracy of both parts to absolute with a value of, let's say 0.0001
Good luck.
John
Reason is you need Advanced Assembly Licence. if not Merge/Inheritance Feature In Part Modeling will be Grayed Out.
