Merged Boundary Blends
- August 16, 2013
- 9 replies
- 3892 views
I am mystified.
I am no expert on surfacing, but:
I was pretty sure I could create a series of boundary blends and merge them to create a single quilt.
Today, I can't. I end up with a curve, not a quilt.
I have a series of x,y,z coordinates in Excel, which define a domed surface.
I have created , in Wildfire 4, a set of datum points offset from a coordinate system, using the x,y,z data from excel.
I created a series of datum curves through these groups of points.
I created a boundary blend, using an adjacent pair of these datum curves as the Direction 1 curves and the curves across the ends of this adjacent pair of curves as the Direction 2 curves.
I repeated this process, until I had a set of boundary blend surfaces that resembled what I wanted to create.
I then tried to merge adjacent pairs of boundary blend surfaces to create a single quilt defining the whole part surface.
That's where it went wrong: I was left with a curve at the join between the adjacent boundary blends, instead of the quilt I was expecting.
I'm sure I've done this successfully many times in the past (on WF2), but now I'm starting to doubt my memory and my strategy.
I would appreciate some assistance here, as I am stumped on what I thought was a pretty simple exercise.
WF4, m220
Cheers,
John
sclose, copy, circulate or in any other way use or rely on the information contained in this e-mail. Such unauthorised use may be unlawful. If you have received this e-mail in error, please inform us immediately on +44 (0) 1963 370551 and delete it and all copies from your system.
