Missing GD&T on PDF from drawing export
Hello, I am newer to CREO 4.0. When I need to export my drawing to a PDF, my GD&T symbols go missing. Would there be something I need to add in my configuration editor from options? The only way I have found to fix this is to export as a TIFF file.
please attach picture of Creo window and picture of window showing PDF contents.
MH
Hey Steven,
Correct. Every symbol (perpendicularity, concentricity, etc.), it does not show up. See the image.
This is from the drawing view.
Mark,
Please try to move the GD&T symbol in separate layer and use Layer save status before exporting to pdf
I created a new layer, however, I am not familiar with "layer save status" where do i find that?
Go to layer tree, RMB and then you will see third last option is Save status. See image
Hey Steven,
My settings match yours, except under fonts: I have USE TRUE TYPE FONTS.2017-04-27 08_37_00-PDF Export Settings.png
set Stroke All Fonts option and export PDF.
MH
Hey Martin,
Yes, I got the symbols to show on the PDF, Thanks! I clicked  Stroke All Fonts.
Thanks again
All GD&T symbols in Creo 4.0 use the new Arial WGL TrueType font.  They should go into the PDF just fine regardless of PDF output settings.  Are you using Creo 4.0 F000 or M010?
Actually, this is not correct.  The default font for Creo 4.0 is indeed the new Arial WGL font but the GD&T symbols actually use the SYMBOL font.
(This is using Creo 4.0 F000.)
Suddenly I am able to reproduce this.  Trying to figure out what changed...
I'm still not entirely sure how I'm creating this condition, but once it happens the PDF output settings don't fix it.  (Again, this is F000.)
Use TrueType Fonts
Stroke All Fonts
Stroke Non TrueType Fonts
Edit:  It's supposed to look like this:
2-Explorer
June 14, 2017
This is basically what I'm getting as well on Creo 4.0 M010. I can stroke all fonts, but the result looks horrible (like all line thicknesses double on the fonts). It appears Creo 4 no longer has the Stroke Non TrueType Fonts option. The only options are 'Use TrueType Fonts' and 'Stroke All Fonts'. When 'Stroke All Fonts' is selected, there is an additional option to Add Searchable Text. The option that fixed this problem in Creo 3 (Stroke Non TrueType Fonts) is missing in Creo 4 M010.
This is an unfortunate surprise when deadlines are missed because the PDF output was bad on something was fine the last time it was output to PDF.
