ModelCheck - Parameter Text All Caps
  • January 10, 2018
  • 5 replies
  • 4219 views
Is there a way to use ModelCheck to require the text within a string parameter to be all caps? We have a parameter that's used within a drawing and it should always be capitalized.
There is a SPR 2848239 on this topic and they say they have fixed in Creo 2 M170 and others,
but still Creo 2 M180 & Creo 4 M030 has the same issue. Unable to update to uppercase for parameter notes.
https://www.ptc.com/en/support/article?n=CS203024&language=en&posno=1&q=SPR%202848239&source=search
@manjunathrv Do you know if the NOTE_CASE check will work with a STRING parameter in a .PRT, .ASM. or .DRW? The PTC help documentation keeps referring to NOTES (which I believe is drawing focused) which makes me think it won't work for STRING parameters in a .PRT, .ASM, or .DRW? We have a DESCRIPTION parameter on all Creo objects that should always be capitalized.
Yes, NOTE_CASE is applicable only on drawing. This is the limitation for us too since we have all the parameters in the model which is called on the drawing.
Also currently the notes in the drawing title block also can't be updated to uppercase since they are part of format;
MC just identifies the lowercase text for title blocks.
