Modeling Help: Protrusion normal to a non‑planar complex internal cylindrical surface.
I am using Creo Parametric Release 10.0 and Datecode10.0.1.0
Guidance on the workflow to Create a protrusion that stays normal to a complex internal surface.
    tbraxton
    tbraxtonAnswer
    See the solution post in this previous thread it deals with the general problem of holes normal to a surface. A reference model is included which provides an example of how to do this.
    https://community.ptc.com/t5/3D-Part-Assembly-Design/Pattern-to-twist-with-a-geometry/m-p/969470#M136234
    kdirth
    You can place a point on the surface then create an axis referencing the point and the surface.  The axis will be normal to the surface at the point.
    tbraxton
    tbraxton22-Sapphire IIAnswer
