Multi-Line Title
Mostly, we keep the title of our parts and assemblies reasonably short.
As a result, when we show the &title parameter in our drawing format, it fits nicely.
Occasionally, though, we just can't keep them short enough, so they end up as two lines.
An example:
slide carriage plate with locking device and slide
I make that 51 characters long.
We split that into 2 lines:
However, there seems to be no easy way to make a parameter have 2 lines of text.
I have seen people just type in the 2nd line, whilst using the parameter fo the 1st line.
I usually create a new parameter - &title_line_2 - and add that into the format.
Sometimes, I just reduce the text size on the drawing.
It's a work-around, though and others are not always diligent enough, or don't have time, to do the same.
Equally, the reduced text size is not to standard.
What is the proper solution?
Somebody out there has solved this problem.
In addition, I am comfortable that, when we migrate to Creo 3.0, the new, totally re-vamped, class-leading, Autocad-crushing Pro/detail look-alike (Yes, tongue ever so slightly in cheek) will have this and all other imaginable drafting issues and problems addressed.
Until then, however, I am keen to hear your suggestions.
John
