Multi model Drawing
HI I have one multi model drawing.
i want put a note for each model.
how do i find the ID associated with tho model?
e.g.
each model has a parameter nemed "CODE"
I Want put a note:
&CODE:0;
&CODE:1;
&CODE:5;
thanks.
e.g.
I Want put a note:
&CODE:0;
&CODE:1;
&CODE:5;
thanks.
Alternatively, you could "Switch Model" your way through all the models in your drawing. For example, switch to model01, then add the text for the parameter, without a corresponding ":##" at the end, like "&CODE". The proper numeric session ID will be appended to the text that is stored in the note. Switch to model02, add the "&CODE" again, and you'll see the ID for that model will be added.
It's pretty inconvenient, but it works.
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
