Multiple Deleted Parts
  • July 26, 2018
  • 3 replies
  • 1658 views
When adding parts to an assembly, if there are parts deleted, Creo will merge all of the deleted parts into one BOM table block. Is it possible to have Creo not merge all into on "DELETED" block in the BOM table?
For example, if there is an assembly with 5 parts deleted, the BOM table will show ONE "DELETED" block with a quantity of 5. I need all 5 deleted parts specified in the BOM table.
Why do you need to show deleted parts? If deleted, they no longer show in the views and therefore are not in the BOM structure.
For revision purposes so the reader can clearly see that a feature of the part or assembly has been removed from the previous REV
StephenW
If your BOM shows "DELETED" after you have deleted a part in an assy, you have some sort of customization that has been done to create that line. It is not "out of the box" functionalilty.
You'll have to give us a LOT more info on what your table looks like and the customization that was done to make that happen.
