Multiple sub-level mechanisms do not function in top level assembly
- November 7, 2013
- 39 replies
- 22177 views
Platform: Creo 2.0 M030
Problem: Mechanism constraints broken on a simple assembly with two synchronized hydraulic cylinders that extend/retract and pivot around a common axis.
Additionally, there is a guide-plate that controls the arc of the devices on the ends of the cylinders. That guide plate also has the ability to move back and forth in a slot. The model did at one point perform nearly as intended.
I would appreciate some feedback on how this assembly could be created.
Thanks!
