Must be a Monday
Can anyone tell me why Pro makes life so difficult?
I have a part in my assembly, and like all other mojor parts, I have a common coordinate system in the part that matches the ACYS0 of the assembly. In the case of this part, it lies far outside the part. Now I am going to use this part on both the left and right side of my assembly (it is a door handle) so I needed to add a new coordinate system to assemble the part on the other side of the assembly. As the part has its own center plane, logic would dictate that I could mirror the CSYS to get the new one - but not in Pro/E, because pro won't mirror CSYS's.
So I have to make a point at CSYS0, mirror that point across the center plane., create a new CSYS at the new point, then create ANOTHER CSYS over the new one to allow for the rotation (part is not parallel to the center plane of the assembly). Why does it take 4 features in Pro to do what should be albe to be done in 1?
- Monday rant off -
Jeff Sampson Engineering
- Monday rant off -
