Need help with drawings in Creo 2
Okay I'm in Pro E Creo 2.0 and working on a drawing. I normally work on NX and these two do not work the same. The original assembly I set the drawing to was named incorrectly so I did a save as on the assembly. I am trying to replace the old assembly in the drawing with the new one that has the correct name and it's a big fail. I am able to "set" the new model in the drawing but cannot get the views to update to the new model. Now this drawing pulls in both models if I close and re-open it. I am unable to delete the old model from the drawing without getting the error "Cannot delete model with views using it" How do I get rid of the old model and update the views to display the new one?
