New part starts with wrong scale
I am making a model based on millimeter units.
I did once make a unit conversion from inches to millimeters.
I added some 5 parts with no problems to the skeleton model.
The latest par I am making acts funnily: I start After modelling the part, I copy the geomtery from the skeleton. With the ready part I am trying to assemble it to the assembly:
The part appears very very small, it is way out of scale compared to the assembly.
Apparently there is some problem, possibly with the units converted. When I measure the copied geometry, the measures seem to be exactly ok although in inches. After that I use file => prepare => Units => change. Even if I do not change the units the scale of the new part is totally wrong.
How would I solve this?
