7-Bedrock
April 11, 2014
New to Creo - Parameter Roll-Up in Assemblies
  • April 11, 2014
  • 14 replies
  • 7493 views
I am new to Creo and I am guessing this is a basic thing. I have created a Parameter in my Part and Sheetmetal templates for Total Estimated Weight. I have also created that same Parameter in my Assembly Template. I have relations in the Part and Sheetmetal files that allow for adding weight manually if these are purchased parts, or welded, to had weld weight. In my assembly I want to total all the "child" weights into the "parent" Total Estimate Weight Parameter, but I am not sure how to write a relation to do that. Can someone help?
Mike
Hi
Creo automatically calculates weight and assign this value to a system parameter if you set the mass_property_calculate = automatic in your config.pro.
The name for this parameter is pro_mp_mass
If you want to assign this value to your own parameter you can simply add the following relation to your start part.
weight = pro_mp_mass
Note that these calculation are based on the volume and density of each individual part in your assembly and not based on any weight parameter you may have added to the individual parts.
Hugo
mwick7-BedrockAuthor
7-Bedrock
April 11, 2014
Hugo,
That is my issue, I need to be able to calculate the total weight based on the user defiend parameters of the individual parts. Not all the parts in my assemblies have an acurate density or even a model. I wish I could rely on that, but unfortunately that is not always the case.
Thanks though
Mike
Mike
Try this:
1. Create a real parameter (weight) in your model and specify the correct weight
2. Add the folowing relations to the part
mp_density=weight/mp_volume(“”)
/* The relation will now change the density according to your specified weight
/* This is an old relation we used previously and has not been tested with creo
Hugo
7-Bedrock
April 22, 2014
Thank you all for the information. I have come up with some relations and parameter mixes to be able to roll up the weight that is needed. By using the Hugo's suggestion of changing the density to affect the mass and an additional process change I can roll up the mass of parts into the actual mass of the assembly quite effectively.
Thank you all again.
Parameters:
TOTAL_EST_WT=(Real) - This is the parameter the drawing reads
EST_PURCH_WT= (Real) - use if purchase weight is known and model is "estimated" - aka non-exact solid
WELD_WT=(Real) - use this if weld weight is known - otherwise we have setup ProWeld to add to mass
Relations:
/*Calculating Weight
IF EST_PURCH_WT!=0
mp_density=EST_PURCH_WT/mp_volume("")
ENDIF
IF EST_PURCH_WT!=0
TOTAL_EST_WT=EST_PURCH_WT
ENDIF
IF WELD_WT!=0
TOTAL_EST_WT=pro_mp_mass+WELD_WT
ENDIF
IF WELD_WT==0 & EST_PURCH_WT==0
ENDIF
