Obtain function or contour lines of a surface
  • June 22, 2019
  • 0 replies
  • 714 views
I have several models that I need to calculate the amount of support required for 3D printing without using slicers.
I was thinking of calculating this using the function for the surface of the model i.e. f(x,y) or using.showing the contour lines on the model's surface.
I was wondering if it is possible to obtain the function for the surface i.e. function for a sphere is F(x,y) = +-sqrt(1−x^(2)−y^(2)).
I am not sure that obtaining the function for any arbitrary surface is feasible or practical, so I figured that obtaining the contour lines of a surface could be easier. Is there a way to do this?
Any help would be greatly appreciated. Thank you.
