OIT problems
I recently upgraded video cards to NVidia K2000 to take advantage of the performance improvements in Creo 2.0/3.0 with OIT. Originally I installed driver version 320.78. I later upgraded to driver 340.52 but that did not affect the issue below. We are running Creo 2.0 m100, but this issue also repeats on Creo 3.0 F000. Running Win 7 64 bit.
We have a machine design with transparent windows. When I set OIT using the config option "blended_transparency independent" the display of the machine is incorrect at certain viewpoints. That is, if I spin the model and look thru one window I see the components inside the machine (sub-assemblies) and they show correctly; however, looking thru a window on a different side of the machine 90 degrees around shows none of the internal subassemblies. Setting "blended_transparency blended" corrects the issue but will remove the performance improvements of OIT.
Any suggestions? Anyone else seen this?
Bill Chapman
Email: -<">mailto:->
Tel: 708-496-3100 | Cell: 708-205-5705
[cid:image001.jpg@01CFB176.CE73B320]
Bill Chapman
