Opening an NX step file with multiple (.) periods in file name Creo View 4
  • May 10, 2017
  • 2 replies
  • 1945 views
Good Morning,  I am having problems opening files I used to open in Creo View 3.1.   These are files created out of NX and have multiple periods in the file name Example: 23428886.geo_fin001.002999.stp
For a work around I can change the extra periods to underscores and most files work but not all.   Has anyone else experienced this since upgrading to WC 11 and Creo 4?
Mahesh_Sharma
22-Sapphire I
May 16, 2017
Mark,
Tested couple of step files from NX with multiple periods in Creo View 4.0, it worked well.
mhess1-VisitorAuthor
The file ended up being weld points,  Which are just points.  Trying to figure how to configure my Step recipe file so Creo will import points.
