Opening up the drawing of a part quickly.
  • April 15, 2010
  • 4 replies
  • 2604 views
Hello; In my work place, we name name all of our parts the same thing. For example Nut.prt would have a drawing called Nut.drw. For some reason, when I have a drawing open but no part, and I click open, it defaults to its respective part. However, when I have a part open but no drawing, and I click open, it has the first part in the library in the text box. I'm wondering if there is some way to set it so that when I click "open" when I have only a part open, that it will have its respective part in the text box automatically. OR Is there some clever way to set a mapkey so that if I have a part open, I can click the key and it will open its drawing. Both the drawing and part will always have the same name. Thanks!
PhilipRoy1-VisitorAuthor
In my workplace we name all of our parts and drawings the same thing***
What if you used the Pro-E browser window instead of the "Open" command? If you browse to the first item that you want that day, then re-expand the browser window, will you be browsing in the same "neighborhood"? Or does it default back to the first file in that folder? I agree that what you are experiencing is a hassle, especially when dealing with very large folders.
Have you guys tried to use SEARCH (upper right in file browesr) to filter large, dense folders?
