optimizing spring rate with wildfire 4
- February 8, 2011
- 1 reply
- 2211 views
hello
i am trying to let wildfire optimize a spring rate with the optimization tool
the problem:
i would like to find a springrate for a mechanism.
a force A is forcing the mechanism to move.
a distance B should be reached.
the tool is optimizing something, but the result are not as expected
i would like to find wildfire a springrate for the force A and distance B
what i did:
i created a meassure for the distance
i created a parameter (feature parameter) for the spring (>spring_stiffness)
i created a paremeter springrate
i created a relation to steer the parameter spring_stiffness. (spring_stiffness:fid_featurenumber=springrate)
i went back to application standard and created a analysis feature (dont know how its called in english) (>insert/model relation?) for the distance
i did a optimization wich was: change the paramter springrate and get distance to B
the optimization did find a value for the springrate, but with this springrate the distance is not B its about 10% more.
the real model is much more complex but i created a very simple model wich should show the same.
thanks for any help
