Option for disabling tangent edges in drawings permanently
  • May 30, 2012
  • 11 replies
  • 7320 views
I'd like to disable them by default, and only turn them on in drawing views when I need them. Is there a way to disable them thru a config option? I've looked and didn't find anything.
I know there is an option to turn them off altogether, which will turn them off in the model and I don't want that.
Thanks!
Best answer by MikeMinsterkett
I do a lot of 2d drawings. When I insert a drawing view by default it show no tangent edges. You can still see them in the model though. If you go to drawing options there is a option tan_edge_display_for_new_views. Mine is set to default. I like it this way & if I want to change it on a certain view I do that with the drawing view window.
KrisR1-VisitorAuthor
What version of Pro/Creo are you using?
I've looked in my config.pro options and don't have this one. If I type it in it doesn't recognize it, either.
Wildfire 5.0. You have to go to file, drawing options on the 2d drawing.
