Options Module - Part assignement
  • September 28, 2017
  • 8 replies
  • 3084 views
I have 4 locations and 4 types of bosses with different  profile & thickness. Currently I have created a total of 16 bosses in my module (4 types at each of the 4 locations) and assigned choices to select any one type of boss at a location.
I was exploring a option where in, I have only 4 types of bosses in my module (instead of 16) and a way to assign them at the available 4 different locations. Please help! Suggestions are welcome. Thanks in advance!
Dale_Rosema
One possibility would be to set up (4) point tables with the points you want for each set of bosses.
Place the first boss on the first point of the first table and pattern the boss using the point table. That should get you your first set of bosses.
Repeat for the other (3) bosses.
Thank you for your reply.
I have requirements to have 4 different types of bosses at different locations at the same time. Like
type 3 at loc 1
typ 1 at loc 2
typ 4 at loc 3
typ 2 at loc 4.
 Will this be possible using pattern option ?
StephenW
A screenshot of what you are trying to accomplish would probably get you more help.
