outdated component/feature
  • March 17, 2015
  • 10926 views
Hi everyone, I have a model that contains a LOT of parts/assemblies. When I open the model, I always have a ton of errors. The main one is "Outdated Component/Feature". Does anyone know how to fix this? We do not have Windchill here, so I have to manage all the parts myself. I realize how crazy this is, I used to work at a place where we did have Windchill so I am painfully aware of what I'm missing there. I have a feeling that would prevent these errors. If anyone has advice about managing files without Windchill that would be appreciated as well.
Thanks!
I'm in the same situation as you are and it's a real pain. You have to be very rigorous on the links you have between parts and the name you give.
Before doing changes in big assemblies I usually make a zip of my project in order to be able to go backwards if necessary.
Anyway, without PDM it's a big waste of time. I'm in a small company, and I'm the only who thinks this would give us a boost having it. I've given up !!
Next place I'll be going there will be PDM for sure !
Rocks11-VisitorAuthor
Thanks I appreciate it. Sounds like we are in exactly the same situation. I never thought of making a zip file of it before, I will have to try that. It's really almost impossible to manage, I have a model with thousands of parts. I'll spend hours fixing the problems, save everything, close it, and the next time I open it, brand new errors. It never ends.
What kind of errors do you have ? Missing components ?
