Output from cgm files.
Hello;
I'm generally a Solidworks user, but someone sent us some cgm files, & I'm trying to do simple tasks such as print a pdf or export as
a dxf etc., but the files opened in PTC Creo take maybe around 7 minutes even to just send to a printer. It says the PTC Creo Parametric (Not Responding). Evenually the file completes. Like a print may take around 7-10 minutes. I had tried it with the Pro E Wildfire loaded on the machine, first & got similar results with the error; xtop.exe is not responding. Like I say the file eventually goes, but wondering if there's anything that would pick the pace up etc., or why this is acting like this.
Thanks in advance for any input;
Rob_D PTC Creo Parametric 3.) M050
