Override value in Dim Properties will not work.
  • March 11, 2014
  • 5 replies
  • 2676 views
Hell I'm trying to fake in some dimension but everytime I enter the value I want in he override value box and hit enter or "OK" it changes back to the oringal dim.[URL=http://smg.photobucket.com/user/Djstorm100/media/Pro-E/2014-03-1109-09-08_mti_work_pcContains_zps3f977ae6.jpg.html][IMG]http://img.photobucket.com/albums/v512/Djstorm100/Pro-E/2014-03-1109-09-08_mti_work_pcContains_zps3f977ae6.jpg[/IMG][/URL]
Best answer by StephenW
If it is a created dimension in the drawing, you can use the @o as described above and to get the tolerance, you can use the superscript/subscript functionality.
@O 100 {2:@++.05 @#}{3:@--.02 @#}
Dale_Rosema
Don't for the the @O ("oh" not zero - my trick to remember this is that you are going to own the dimension yourself by overiding it - a bunch of O's).
So @O 13.375" should show up as 13.375"
At least this is old school and should be done in the display tab. Not sure of the overide feature there.
Thanks, Dale
dholloman1-VisitorAuthor
Right, but at the same time if I need to place +0.05 and -0.2 tolerance it will not let me place those.
Dale_Rosema
Not as nice, but:
@O 13.375 +0.05/-0.20
is an option.
