Parameter dialog crashes Proe
  • June 24, 2010
  • 4 replies
  • 1217 views
I have an assembly that started with a family table that I later split
into separate assemblies because of screwy behavior. Any version of the
assembly crashes every time I open the parameter dialog. I need to
change a parameter, but it just blows up every time I open the dialog.
Other assemblies and parts let me open the parameter dialog and change
them, but this one doesn't. Has anyone had this problem before?
Ken Sauter
DRS Reconnaissance Surveillance and Target Acquisition
Infrared Technologies Division
PO Box 740188
Dallas, TX 75374
214-860-6826
NOTICE: This e-mail transmission (and/or the attachments accompanying
it) may contain confidential or proprietary information belonging to DRS
Technologies or the sender. The information is only for the use of the
intended recipient. If you are not the intended recipient you are hereby
notified that any disclosure, copying, distribution or the taking of any
action in reliance on the contents of this information is strictly
prohibited. Any unauthorized interception of this transmission is
illegal under the law. If you have received this transmission in error,
please promptly notify the sender by reply e-mail, and then destroy all
copies of the transmission.
"This (document/presentation) may contain technical data as defined in
the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10.
Export of this material is restricted by the Arms Export Control Act (22
U.S.C. 2751 et seq.) and may not be exported to foreign persons without
prior written approval from the U.S. Department of State."
Seems like an invalid parameter or parameter name...
Can You remember which parameters should be there? If yes, try a note showing these parameters one by one and look for irregularities.
What if You use parameters somewhere else, e.g. in the search dialog, a family table, etc.? Can You open the relations window?
Try to switch to the old parameter ui: set the option new_parameter_ui to no.
Then open the parameter dialog, make your changes, save and try to switch back to the new ui.
2-Explorer
June 25, 2010
Ken,
What about the Relations dialog (Tools > Relations)? Can you open that? If so, what happens when you expand the Local Parameters in the lower portion of the dialog?
Also, how about adding the Model Params to the model tree (Settings > Tree Columns)? You will be able to see all the parameters and edit their values if necessary.
Ron Thellen
CAD Administrator
Engineering & Manufacturing Applications
Government Communications Systems Division
Harris Corporation
321-729-7502
kwsauter1-VisitorAuthor
Thanks to Ron Thellen for the answer that worked!
My original post:
The answer that worked:
I was able to edit the parameters in the model tree and got no crashes
while doing it. Thank you! I hope this helps somebody else.
Ken Sauter
PO Box 740188
Dallas, TX 75374
214-860-6826
