2-Explorer
September 10, 2018
Parameter maximum value
  • September 10, 2018
  • 5 replies
  • 2556 views
Hello
If we create a string type parameter, what max number of characters can be set for a value of parameter?
Is it possible to store 300 characters as a value of parameter... If yes, what is the solution...? If no, is there any alternative for this solution..? Note we cannot use ... Parameters only we need to use due to dependency of other programs.
Any idea would be of great help.
Thanks in advance....!
Regards
Ketan
Creo hard limits parameters to 80 characters and there is currently no way around this.
https://www.ptc.com/en/support/article?n=CS61011
What are you trying to accomplish with a 300 character parameter string?
You can create 4 parameters to capture the information, then concatenate them into a string for placement on a drawing.
2-Explorer
September 11, 2018
We need to pass parameter value to other progame and that mapping is there for only parameters. Not for note...
Integration wasn't thought out too well.
Can you pass multiple parameters to your other program and then do the concatenating?
