Parameter with multiple values
  • January 9, 2018
  • 5 replies
  • 2832 views
Is it possible to have a parameter, that contains some values pre defined?
See example:
catia knowledge check
http://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/fundamentals%2Ffundamentals%2Ffund_seven_sub%2Fabout_Restricted_Value_Parameters.html%23 Look up restricted value parameters in help. The user will be presented with a drop down list of values from which they can select. Not exactly the functionality shown in the video. You'd have to setup relations, pro-program, etc. for the model to update based on the parameter value. Regards, Dan N.
18-Opal
January 11, 2018
CAD_user14-AlexandriteAuthor
Generally, this is what I need to do. But let's imagine that I create this in my computer, and after this I open the same file, where this isn't configured. It won't work, right?
No, it will continue to work.  The restricted parameter definition is stored with the file.  No one else who uses this file will need the original restricted parameter list unless they want to create new files with the same restrictions.
