PARAMETERS AND RELATIONS
  • October 20, 2014
  • 6 replies
  • 3188 views
Hi everybody,
i have a question about relations and parameters: i'm trying to make an udf to cut an involute gear but i cannot add a variable parameter as i've make them on part. if i make variable parameters on a feature i have to replicate on all the features, correct?
do you have any suggestions?
thanks!
Best answer by SergDubrovskiy
A first create Annotation Elements.
Add all parameters and add relation, if needed.
Create all features, if need, I add realation for feature.
To UDF I add all elements with AE.
AE includes all parameters for create UDF.
This parameters I add to variable parameters UDF.
Image for UDF
I create for UDF Annotation Elements and add to him parameters and relations.
cspinelli14-AlexandriteAuthor
thanks, but you add annotation AFTER inserting UDF correct?
for example, in the image you added, if i want to insert UDF and change diameter or number of teeth when i'm inserting UDF is it possible'
Image for UDF
